H stuck in 5th gear
Jeff
08-03-2003 16:04:49
My H is stuck in 5th gear. How do I get the pin out of the shifter handle to put the gears back in line? It seems to be stuck fast (the pin)
Jailkeeper
08-03-2003 22:31:13
 Re: H stuck in 5th gear in reply to Jeff, 08-03-2003 16:04:49
Jeff, my H had metal caps on each side of the pin. I had to get the caps dug out and then drive the pin out of the shifter. You may have to push down on the shifter at the same time you are driving the pin out. That's when you need a third hand.
gene b
08-03-2003 16:13:30
Drive it out with a punch they are a good fit so it wont drive easy. Use a good pin punch not a tapered one.
