Farmall H pistons and sleeves
Joe
08-03-2003 17:29:15
I had overhauled my friends H and he has maybe 30 hours on rebuild. (Guess hrs) Anyways, it ran very smooth and all at once it made a bang. So I took off the pan and a sleeve had totally come apart and was laying in the pan in pieces. Also, the skirt was broke off the piston. A local machine shop had installed the sleeves so I would think they would have checked the bores for out of roundness. Has anyone had the same problem? Could it have been a defective sleeve? Any opinions would be appreciated. Thanks
Jim
08-03-2003 19:21:53
 Re: Farmall H pistons and sleeves in reply to Joe, 08-03-2003 17:29:15
While mowing hay in May 2003. I lost a sleeve. My 1942 H had been overhauled by the original owner about 6-7 years ago. I had run it for about 2 years with a loud clicking off and on in the engine. My sleeve was jumping up and down. In May it finally let go. A friend (and mechanic) told me to re-build the one cylinder. He ordered me a 1 cylinder rebuild kit. I cleaned oil pan and cylinder wall. He told me to put sleeve in with locktight and let it setup for 24 hours. Well it was about 3 days before I put it together. So far It seems to be doing fine. I will find out in about a month as I will start to mow again. The rebuild kit I used consisted of a sleeve, new piston, rings, and wrist pin. The piston does not match the other 3 but it does not seem to present a problem. The tractor runs smooth and pulls good. I put locktight on the sleeve and block. I also put sleeve in the freezer for several hours before installing. This makes it contract and installing is easier. The kit's cost was $95.
