Order Farmall Cub Parts Online
Does Woods make a mower for fast hitch cub?
Mark R.
08-04-2003 06:20:51
Someone told me there was a mower made for the single point fast hitch. Can anyone verify this? I searched on google, but couldn't find a picture. Mark R.
NCJohn
08-05-2003 10:52:53
 Re: Does Woods make a mower for fast hitch cub? in reply to Mark R., 08-04-2003 06:20:51
Mark, I have been informed by Woods dealers that the RM42 Woods for the CUb is no longer manufactured. Yes, it is more of a bush-hog unit rather than a finish mower. You might get lucky and be able to find a used Woods 59 belly mower with the fast hitch idler bracket. I believe you will need the belt gearbox to be able to use it.
George Willer
08-04-2003 06:53:21
third party image
Mark,
Check out "Tractor Buddies", a small business owned by Paul Bazzetta in Wisconsin. He is a Woods dealer.
George Willer
Mark R.
08-04-2003 08:06:35
 Re: Re: Does Woods make a mower for fast hitch cub in reply to George Willer, 08-04-2003 06:53:21
Thanks George! I was wondering what kinda job those mowers do? Can they be used on a nice lawn, or are they more for bush hog type work? Thanks again. Mark R.
gene b
08-05-2003 05:06:05
 Re: Re: Re: Does Woods make a mower for fast hitch in reply to Mark R., 08-04-2003 08:06:35
you need a belly type to do the best job as they will have three blades that type rear is more of a brush-type. Mite want to check into the pull behind finish type that has their own engine and you just pull it behind like a trailer. These do an excellent job they run around 1200 or so.
Mark R.
08-05-2003 13:35:43
 Re: Re: Re: Re: Does Woods make a mower for fast h in reply to gene b, 08-05-2003 05:06:05
Thanks alot I'll look in to it
