A/B Clutch Adjustment and Spark Plug Gap
Jeff_MI
08-04-2003 06:43:55
I put a new clutch disk and throw out bearing in my B,and I put everything back together correctly (as far as I know). The problem I'm having is the throw out bearing isn't engaging the pressure plate until the foot pedal is almost pushed
all the way in/down. I had to move the pedal-to-"clutch rod" adjustment all the way back to the end of the clutch rod to accomplish this, so there must be something wrong. Any suggestions?
Also, what is the correct spark plug gap (Autolite plugs)? Thank you.
Gary-Miss
08-04-2003 17:27:10
 Re: A/B Clutch Adjustment and Spark Plug Gap in reply to Jeff_MI, 08-04-2003 06:43:55
I would set the pluggap at.032. The book calls for .023, but, this has to be a misprint cause I can't get one to crank with the gap this close. Not sure about the clutch. Your yoke that pushes the throwout may be bent. I have seen this many times. You have to put the cotter pins back in. Somethimes these clutches can be a pain in the fanny.
