656 Hydro D.O.A. ??
Tom
08-04-2003 21:30:53
Was over at a friends this weekend helping them out,his 656 sometimes wouldn't go forward after being in reverse, shut down engine, restart goes just fine, or hit reverse, goes foward again. After leaving he was working & tractor trans. lever (one on left)stuck all the way foward doesn't move, tractor doesn't move. Hope there's cheaper than rebuild fix for it as it's too nice of machine for boneyard! If no easy fix what's this really clean gas model worth with bad trans?
RAS
08-05-2003 08:04:23
 Re: 656 Hydro D.O.A. ?? in reply to Tom, 08-04-2003 21:30:53
The problem could be in the drive control valve. This is the valve the lever moved on the left side. Some times with wear when you move the lever it does not move the valve in or out. What I mean is when you move the lever over the bottom of the lever moves the valve out. Next time when you it stops move the lever side to side and see if it moves. This is just a quick check.
Tom
08-05-2003 19:04:30
 Re: Re: 656 Hydro D.O.A. ?? in reply to RAS, 08-05-2003 08:04:23
Thanks for the response RAS, I'll look at it next time I'm up there.
