Fast Hitch #100 Balance Mower pix posted
Evan350
08-04-2003 21:40:25
Over the past few weeks, I saw a couple questions and I even got an e-mail asking how does a fast hitch #100 hook up. I've placed two pictures in the Implement Photos gallery showing how I hitch it to my Farmall 350. I have a couple more closeups of the hookup I could post if there is interest.
Tractor Dan
08-05-2003 17:01:16
 Re: Fast Hitch #100 Balance Mower pix posted in reply to Evan350, 08-04-2003 21:40:25
thanks for the pics have a few questions do you have shims in the fasthitch or do you not worry about them?? i hooked my 100 up to my 350 diesel i made a bracket and mounted a small hydralic cylinder to rise and lower works well but i find my guards are level if not pointed down a little if i lower the fasthitch almost so it drags the guards point up a little and it mower quite well but then i drag the hay that has already been mowed .so is there any way to adjust the pitch on these??
what part of new york are you from??
here is a older pic of my 350 diesel ill have to get some others posted
Link
Evan350
08-06-2003 06:25:31
 Re: Re: Fast Hitch #100 Balance Mower pix posted in reply to Tractor Dan, 08-05-2003 17:01:16
There are two sizes of 2pt fasthitch. Sounds like your mower has the smaller size prongs for the 200 series tractors, which would require a shim to fit the 350. You have some control of the guard pitch by adjusting the right chain, the higher you restrain the downward movement of the fasthitch, the guards point down more. You may have to adjust the left chain also to compensate the sickle bar lift.
Van
08-05-2003 21:39:19
Checked out your homepage, nice family. Those kids sure look like they are having a blast in that spreader, nice 350
dave
08-05-2003 05:30:22
thanks for the photos I use a slightly different hook up for my 300 utility.My rock guard looks different.where are you in ny. dave
