Source for W-9 wiring harness?
Steven@nd
08-05-2003 09:57:04
Got the W-9 running again, finally. Machine shop took a few months to get the valves ground, busy all the time in there. Anyway, the wiring harness is trash, all bare wires. I don't know where to find a new harness either.
Any ideas? Thanks!
Dave M
08-06-2003 05:00:12
 Re: Source for W-9 wiring harness? in reply to Steven@nd, 08-05-2003 09:57:04
I just make my own and wrap it it that cloth friction tape looks real good
Farm w/Junk
08-05-2003 22:39:31
John Brillman makes them like original and are reasonable. For every wires including battery cables it was like $180 for an H. www.brillman.com good luck
Matt
Glenn-WV
08-05-2003 19:20:05
Have you called Bermuda Ken? 608-455-2411
the tractor vet
08-05-2003 17:08:59
Build a new one , If ya weren't sofar away i would do it for ya and it would look factory.
Steven@nd
08-05-2003 19:41:50
 Re: Re: Source for W-9 wiring harness? in reply to the tractor vet, 08-05-2003 17:08:59
Can you build a new one if I send the old one?
Email me at smgussey@yahoo.com if ya can and let me know a ballpark figure on $$$
Thanks.
the tractor vet
08-05-2003 20:45:45
 Re: Re: Re: Source for W-9 wiring harness? in reply to Steven@nd, 08-05-2003 19:41:50
I probley could but i much perfer to do it on the tractor to get the lay out wright , they are easy to do but the hard part is getting the wire loom the main harness for the engine only has three wires one 14 ga. yellow and one 12 ga.blue and one 14ga. black and maybe a head lite wire on a W9 and that should be a 14 ga. purple the dash harness has a gray 12 ga. a red 12 ga . and what ever else ya can sort of cheet on i use the uninsulated end and use a real good delco heat shrink over the endsthis is what give the factory look .
John A
08-05-2003 10:27:33
Steven@nd, Where have you Been?? I haven't seen a post or comment from you in quite a while. Glad to see your back!!! OK, To your question now. I am pretty sure O.E.M. Tractor parts should have a new one. Call 800-283-2122.Hope this helps.
Good Luck,
John A.
Steven@nd
08-05-2003 14:12:56
 Re: Re: Source for W-9 wiring harness? in reply to John A, 08-05-2003 10:27:33
I've been working! Worked with a friend making hay starting in June, then made hay on the family farm, now harvesting. Finally got an inch of rain and a day off. It's been busy all summer.
I'll check my OEM catalog for the harness and with agri services too.
Thanks
Steven
Bob M
08-05-2003 10:24:58
Try Agri-Services in Alden NY (716-737-6618). I've not used them myself but have heard from others they make good reproduction harnesses for IHC.
Paul in Mich
08-06-2003 06:35:28
 Re: Re: Source for W-9 wiring harness? in reply to Bob M, 08-05-2003 10:24:58
I bought the complete harness for my Farmall H from Agri-services, and they did a wonderful job. I ordered by phone and would suggest likewise as they can best figure out what you need, since there are several variations such as Mag vs Distributor, and regulator location. Good luck.
