QUESTIONS ON 656
John
08-05-2003 18:53:22
I am looking to purchase a farmall 656. I am not to picky on options, such as gas/diesel, or front end types. what are the pros and cons of this tractor? im doing my "pumpkin/sweetcorn farming with my M and the M is a good tractor, but i would just like to get something a little bigger and i'm leaning towards a 656. I live in michigan and have no way to haul one if i pick one up somewhere...anyone in michigan or ohio interested in selling/hauling one to southern michigan?? please email back any info..thanks
Dick Davis
08-07-2003 03:38:46
 Re: QUESTIONS ON 656 in reply to John, 08-05-2003 18:53:22
John, I think you got your answer. Sorry you had to read the name calling and "preachy" nature of some of the postings. Ever notice how some guys opinions are the only ones that count? The 656 is an excellent tractor but some are worn out. My nickel. Dick Davis
Steve450
08-06-2003 19:28:38
I think what the boys are trying to say is that a 656 is an "M" class tractor. A 656 will do more work than an M, but in the grand scheme of things, the 656 is a medium sized tractor just as an M was in it's day. The 656 was built to replace the 560, which replaced the 450, which replaced the 400..... all the way back to the M.
I don't think you could go wrong with the 656 to replace your M. I did the same thing- acually I replaced a 450 with a 656 and have never been happier. The 656 is the "Big Tractor" on our part time operation and works great. I have a gear drive Diesel wide front with 3pth and it does every thing I need it to do on 25 or so acers. My $.02
dhermesc
08-06-2003 06:12:37
A 656 is a much heavier and much more powerful tractor then a M. Most 656 are turning between 60 and 70 hp while most M turn between 30 and 40 hp. The improved hydraulics alone will amaze you if you have grown used to the M.
Pros: More power, heavier, live PTO, live hydraulics, parts availability is not an issue.
Cons: Use more fuel, not as simple as a M, heavy (interms of hauling), TA can be an issue.
The other thing to consider is that the 656 is getting on in years. Most have been worked hard since day one and continue so as loader tractors and general use (baling, mowing, blading). Finding one in good condition will cost you.
Hugh MacKay
08-06-2003 13:11:41
 Re: Re: QUESTIONS ON 656 in reply to dhermesc, 08-06-2003 06:12:37
If you consider the line of tractors from which the 656 came the incraese in hp is a lot more gradual than you try to make it sound Starting with M, SM, SMTA, 400, 450, 560, 656, 666 and 686 there is a gradual progression of hp. There are also a few parts common to every one of those tractors. As for weight I will be willing to bet there is not a lot more than 1,000 lbs difference in any of them with same equipment, or as close as you can come on equipment. So lets not get picky, John knew he would be getting more power. My recollection was he wanted to know if 656 shared the same kind of durability as the M. That it will do and will give you 10 times the comfort along the way.
I had a Super M, 560 and 656, and each one of them did the same kinds of work on my farm as the previous one. I never found myself often robbing work away from my Super A, 130 or 1066 with any one of them. I do agree with you on one point, the higher we delve into horse power the shorter the lifespan of the tractor. I could be wrong but I don't think you will see 1066, 1086, 1486, etc. around in great numbers when they are 50-60 years old. Although I must admit I am surprised to see so many of them in photos adds, gallery, discussion, with as little as 4,000 to 6,000 hours on them. They must have been bought new by some pretty finincially comfortable old farts. When I bought my 656, 560 and 1066, the projections were done on them putting in between 750 and 1000 hours per year. Must be great to be able to farm and not have to make money.
dhermesc
08-06-2003 13:55:58
 Re: Re: Re: QUESTIONS ON 656 in reply to Hugh MacKay, 08-06-2003 13:11:41
As you state the horse power increases from model to model were gradual, but there are five models (SM, SMTA, 400, 450, 560) before you get to the 656 from a M. The engine increases from 4 cylinder to 6, forward speeds from 5 to 10, live hydraulics, live PTO, 2 or 3 point factory set up. Comparing a M to a 656 is like comparing a Farmall Regular to a M, and the Regular is much more similar. I have pulled a 400 air planter with chemical barrels and a big round baler with a 656 and would never have dreamed of or even seen that attempted with a M. If you where using a 656 on the same equipment as the M, why get rid of the M?
Hugh MacKay
08-06-2003 17:22:29
 Re: Re: Re: Re: QUESTIONS ON 656 in reply to dhermesc, 08-06-2003 13:55:58
Why get rid of the SM; Independant PTO, live hydraulics, 3 point hitch, power steering, diesel,TA, etc. How thick is your skull? All John ever asked for was an opinion on the 656 having as good of lonjevity and durability as the M. I could quite easily tell John knew all the differences in ratngs. You decided to treat us both like dummies.
I also owned a 400 air planter, round baler, haybine, etc. And yes I have pulled them all with 300 but stayed away from all with SM because PTO. Sure the 560 and 656 have more power, but not that much more hp. The single biggest reason for going from gas M, SM, 300, etc to 560 and 656 diesels had nothing to do with power in the 1960's, It was all about fuel efficiency. I also called the 460, 504 and 606 duds just looking at the specs before we ever saw one in the field. That is precicely why none of those 3 ever came to my farm. You didn't read my last post, so I doubt you will bother reading this one. Guess who that makes look like a dummy.
dhermesc
08-07-2003 05:53:17
 Re: Re: Re: Re: Re: QUESTIONS ON 656 in reply to Hugh MacKay, 08-06-2003 17:22:29
I guess its not thick enough to bother anymore. All hail the mighty Hugh.
Hugh MacKay
08-09-2003 19:22:45
 Re: Re: Re: Re: Re: Re: QUESTIONS ON 656 in reply to dhermesc, 08-07-2003 05:53:17
dhermesc: Been away for a few days, while away was thinking may be you deserved an apology, and may be you do, but I don't apologize to people with dual identity.
dhermesc
08-11-2003 06:05:43
 Re: Re: Re: Re: Re: Re: Re: QUESTIONS ON 656 in reply to Hugh MacKay, 08-09-2003 19:22:45
Hugh, your "apology" is worth about as much as your opinion.
Hugh MacKay
08-11-2003 09:45:04
 Re: Re: Re: Re: Re: Re: Re: Re: QUESTIONS ON 656 in reply to dhermesc, 08-11-2003 06:05:43
You didn't get an apology, better read again.
dhermesc
08-11-2003 14:05:59
 Re: Re: Re: Re: Re: Re: Re: Re: Re: QUESTIONS ON 6 in reply to Hugh MacKay, 08-11-2003 09:45:04
I stand corrected.
Here is some advice to help you avoid embarrassing yourself in the future. Stick to production numbers and interpreting serial numbers, you know, things you read in a book or on the internet.
Hugh MacKay
08-11-2003 14:49:26
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: QUESTIONS in reply to dhermesc, 08-11-2003 14:05:59
I'll decide who I take advise from, thank you.
dhermesc
08-11-2003 15:26:58
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: QUESTI in reply to Hugh MacKay, 08-11-2003 14:49:26
Its good to know I'll be reading more of your entertaining posts in the future.
ed
08-07-2003 10:44:31
I'm not sure I would pull an air planter with a gear drive PTO tractor - could be hard stopping with out an overrunning clutch. The M - 686 were all great tractors with each one getting progressively better and more powerful. The 656 would be a good addition because almost everything that fit on the M would also fit on the 656. I beleive thy all share the same durability. The later model 686 I heard had an even heaver rear end that is probably even more durable. The diesel engins were also used on bigger tractors. I would guess that you could turn them up well into the 80hp range. just compair the engin size 310/312 at 70 hp to an oliver 1855 with a 310 putting out well over 100hp.
I also wouldn't call the 504 a dud. We had one years back and it was a great cultivator / spraving / broadcasting tractor. You have to just use it for what it was designed for. It would be a very disapointing tractor in front of a 3-16 pull type plow.
Hugh MacKay
08-09-2003 19:18:02
 Re: Re: Re: Re: Re: Re: Re: QUESTIONS ON 656 in reply to ed, 08-07-2003 10:44:31
Ed: If you re read the thread no one suggested using a transmission driven PTO tractor on a IH cyclo corn planter. Aside from the problem you mention on the PTO pushing you, every time the blower stops the seed will fall from drum, thus 8 to 12 feet missed planting. I always liked planting with 656, lots of power for job, TA at headlands when turning. I have done some planting with 300 a couple of times, a bit shy on power.
When I made the remark about the 460, 504 and 606 being duds, more than just tractor performance went into that decission. On several ocasions I priced new 504 and later on 544. I always found these tractors were priced very close in price to the next larger tractor. I had a 560 new, 460 was at time within $400. 460 was not a factor as I was looking for 60 hp. I later bought a neighboring farm that had a 504 and 656 with it. The vendor advised me not to keep 504 long as at 1500 hours engine had to be rebuilt. He said he never liked the 504 from new, plus by the time he added some optional equipment it cost him as much as the 656 diesel. He bought both new in April 1967. With the added acerage I was planning to trade my 300 on a 1066. After a day plowing with No. 60 3x16 on both 300 and 504, the 504 was the one traded on 1066. In my sandy loam I had often pulled that 3 bottom plow with 300. The part that got me was 504 is rated 7-8 more hp than 300.
The new price tag on these tractors was a factor. That may have been unique here in Canada as I believe IH were trying to force us into buying the British built IH in the 50 hp class and smaller tractor. The US plants couldn't keep up with sales, Doncaster, England was new. Currency was right for IH making money with Euorpean built tractors. IH forgot one thing those smaller British built tractors weren't Farmalls.
I will give one further item on the comfortable M item. My Farmall 300 on 9' New Holland haybine would burn 3 Canadian gallons of gasoline per hour, and no more than enough power. 656 diesel on that same haybine, burned one Canadian gallon of diesel per hour. The 504 and 544 diesels will not do any better. You could say I never worked my 656 very hard. I sprayed, drilled grain, planted corn, baled both square and later round, haybine, and it did all those jobs more economical than any tractor I could have used there. The other job it did every year was plow 250-300 acres with a 510 - 5x16 semi-mount plow. You name any other tractor that will fill that bill.
The Farmall MD and SMD were in their time hailed as the most economical farm power. IH improved that economy with the 656. That line of tractors starting with the Farmall M in 1939 through to the 686 in 1980, was 40 years of the most economical horse power North American farmers have ever seen. No one has done it any better. There are no new tractors on the market today that will match it. So if all this creates a bit of a chuckle for a few that's fine. I will stand by my comfortable M theory, absolutely more power, no question. Getting the job done one time and at the lowest possible cost is what counts.
Rode Hard
08-07-2003 11:21:58
Look out Ed, your crossing the line by questioning Hugh's judgement. You'll be called stupid and thick headed if you don't pull your hat off and say "Yas Masta".
Hugh MacKay
08-05-2003 19:43:57
John: You allready know what you are getting into, a 656 is just an M with comfort. Probably one of the best tractors IH ever rolled off the assembly line. During my farming days I owned 16 different Farmalls in size from Super A to 1066, and I had at least one tractor from each series from letter series to the 66 series. My all time favourite was the 656. Try and go diesel if you can, those 6 cylinder gassers were heavy drinkers. Also stay away from a hydro, great set up if tou need infinate speeds, but there is a price to pay.
I can also tell, you just plain want an M with comfort.
