Oil level for F-20 transmission
GP
08-06-2003 05:31:59
Where do I check the oil level of the tranny on a F-20? I found the check plugs on each of the final drives. I have the add on road gear on the front of the tranny if that makes any difference. Thanks!
JohnG(TX)
08-06-2003 12:12:53
 Re: Oil level for F-20 transmission in reply to GP, 08-06-2003 05:31:59
I have an IHC road box which has its own fill level plug since it blocks the original. See if you have one on your road box. These boxes are not sealed from the transmission and use the same oil.
JG
Chuck
08-06-2003 11:27:22
There is a plug in the front of the transmission to the right of where the coupler is- In your case maybe where the overdrive is mounted. The oil level should be up to the level of the plug. Takes about 8 gallons to fill.
