Pic of a Wide front on a B for Mrs squeakyzig
Dave_D
08-06-2003 21:46:48
I snaped this picture at a tractor show in Gainsville,Tx last summer.
third party image
The only modification needed was drilling the 4 mounting holes.
third party image
Richard C
08-07-2003 06:34:13
 Re: Pic of a Wide front on a B for Mrs squeakyzig in reply to Dave_D, 08-06-2003 21:46:48
If that is the same one I seen at the show in Temple Tx (I think it is) I t is done very well and looks like it came that way.
Richard C
TWDENNEY
08-07-2003 08:37:03
 Re: Re: Pic of a Wide front on a B for Mrs squeaky in reply to Richard C, 08-07-2003 06:34:13
What parts are needed to accomplish this? Is that an 'A' front or a 'C' front? Do the tie rods hook up with no problem?
Thanks.
gene b
08-07-2003 18:48:58
 Re: Re: Re: Pic of a Wide front on a B for Mrs squ in reply to TWDENNEY, 08-07-2003 08:37:03
Easiest way to do it is with an A front. I have one in great shape if you are interested.
Dave_D
08-07-2003 12:15:38
From what the owner told me. The front end is a wide front from a C. All he had to do was drill 4 bolt holes. There are factory casting pads on the B where the holes need to be drilled. Its like the factory planed to offer this, but never got around to doing it.
gene b
08-08-2003 02:24:43
 Re: Re: Re: Re: Pic of a Wide front on a B for Mrs in reply to Dave_D, 08-07-2003 12:15:38
The C has the steering shaft coming down the generator side so he did more changing than what he indicated. There is no way you could bolt the assy to the B without some big changes.
Dave_D
08-08-2003 12:42:27
 Re: Re: Re: Re: Re: Pic of a Wide front on a B for in reply to gene b, 08-08-2003 02:24:43
Gene,
I am sure you right. Thanks for the input.
- Dave
