'40 H engine or not???
Jailkeeper
08-07-2003 06:37:57
I've got an H that I've checked the serial number on and know it is a 1940 model. The engine is what has me stumped -- it has a distributor that sits vertical in the block about 1/2 way back on the right side.
I was just looking at my serviceman's guide and it shows these tractors having a horizontally mounted magneto on the timing cover. Were all of the engines built the same way so they could be equipped with either system?
Red-MAN
08-07-2003 11:59:52
 Re: '40 H engine or not??? in reply to Jailkeeper, 08-07-2003 06:37:57
The engine serial # stamped just below the head on the rear of the block (right side) should match the serial # on the tractor.
Jailkeeper
08-07-2003 19:55:11
 Re: Re: '40 H engine or not??? in reply to Red-MAN, 08-07-2003 11:59:52
Thanks Red Man, that's more of the answer I was looking for.
rustyfarmall
08-07-2003 08:04:53
The magneto would have been original equipment, most of the Hs and Ms were converted to a distributor ignition when it became available, because the distributor is so much more trouble free.
The distributor you have is a Delco, every bit as common as the I.H. type.
Red Dave
08-07-2003 07:09:14
Sounds like the magneto was replaced with a distributor, not an uncommon thing. I think the vertical distributors were aftermarket Delco's. (I'm sure somebody will correct me if I'm wrong.)
