Order Farmall Cub Parts Online
What's the deal with cub throw-out bearing?
Randy Sharb
08-07-2003 08:56:08
I ordered a new throw-out bearing thinking mine, which came off a cub that had been setting for two years,was seized up. The new one doesn't spin either, but they both have grease fittings which seem rather useless if there aren't any moving parts. I don't get it. Anyone else know what the deal is? Thanks.
Phlogiston
08-07-2003 11:09:23
 Re: What's the deal with cub throw-out bearing? in reply to Randy Sharb, 08-07-2003 08:56:08
I'll check tonight and get back to you. Remember that there is nothing wrong with the t/o bearing you have. The one in the tractor lasted some 50 or so years. The newer style t/o bearing will not load the engine like the old style does when the clutch is depressed.
Phlogiston.
Phlogiston
08-07-2003 09:24:28
What you have is a block of graphite or carbon. The lube is absorbed into it. You are coorect in that the t/o bearing does not move, rather the clutch fingers spin against the bearing. Your bearing is from IH. A new, conventional ball bearing unit can now be purchased from other sources and is superior to the one you have.
Phlogiston
slipshod
08-07-2003 15:16:44
 Re: Re: What's the deal with cub throw-out bearing in reply to Phlogiston, 08-07-2003 09:24:28
I am not so sure a mechanical throw out bearing is superior to the graphite one that comes on a cub. Did I hear you say the old one lasted 50 years,and you replaced it because it was working the way it was designed to?
randy sharb
08-07-2003 10:15:56
where does one get a ball bearing throw out bearing?
Bigdog
08-07-2003 12:37:44
 Re: Re: Re: What's the deal with cub throw-out bea in reply to randy sharb, 08-07-2003 10:15:56
Bates Corp.
