First Time Hauling F-20
Greg from WI
08-08-2003 09:50:19
Any ideas how to chain down to trailer? My idea is clevis on drawbar and two cast I-bolts replacing front engine mount bolts to rails.
Randy in NE
08-11-2003 05:19:28
 Re: First Time Hauling F-20 in reply to Greg from WI, 08-08-2003 09:50:19
You need to check with your state DOT. Iowa is requiring 4 independent tie downs. This is more stringent than the federal DOT regs. They also require electric brakes if you are over 3000 lbs. Rumor has it that as of Jan 1, 2004 the nylon web tie downs will no longer suffice. I haven't seen anything is writing yet.
howster mighty fine
08-08-2003 10:25:09
I loop a chain through the drawbar, clevis would work too. front chain goes around the bolster just above the wheel hubs or else just above the tires, of course this scratches the paint but it's my paint. On one F-20 I have a short piece of chain with a hook on it that stays on the front bolster. Would be good for towing too I guess, my 20 always starts.
