F-30 tires
howster mighty
08-08-2003 18:07:47
Well after a year the F-30 is coming together. Finaly got a lull in the wind and sqirted paint today. Yes, I am The Shade Tree Mechanic. But even in good daylight that dark grey is getting harder to see.
My question is the tires. I have a set of 13x36 for the back. Now I always thought there was a spacer that could be added to the front spindle to raise the front end. Boy was I wrong! Like Duhhh, The shaft has to be longer too. So now I am considering putting on a set of good used 7.50 impliment tires. Has anyone done this? I am not sure if they will clear the cultivator brackets.
JohnG(TX)
08-11-2003 10:57:58
 Re: F-30 tires in reply to howster mighty fine, 08-08-2003 18:07:47
There is a conversion which can be done to raise the front end about 3". It does involve adding a 3" section to the lower part of the steering shaft and slipping a 3" spacer over the shaft. This raises the front end up and the lower bolster bearing rests on the top of the spacer. I have a Regular with this conversion, and have seen many others done like it. I have a friend who did it recently with great sucess. It was done when the steels were replaced by rubber. I don't know if it was a 'Dealer' item, or just any garage was doing it. I did not find any mention of it in the parts books and have no idea what happened when IHC sold a tractor with rubber from the factory. You can do the conversion, but it will modify the tractor. Have you considered sticking with steels?
JG
Okla/Kans Bill
08-09-2003 17:45:40
My 27 has 5 50 X 17s on frot and 11 38s on back, and its straight
JEFF
08-09-2003 18:55:18
 Re: Re: F-30 tires in reply to Okla/Kans Bill, 08-09-2003 17:45:40
They started making F-30 in 1931 i have the 186 one made there is NO such thing as a 27 F-30 the tires you are going to use will more than likly hit the brackets
OklaBill
08-09-2003 19:16:46
 Re: Re: Re: F-30 tires in reply to JEFF, 08-09-2003 18:55:18
Sorry, I shoulda wrote 37, but Ive been farming with these tires for 5/6 yrs now. I use it for plowing, discing, pulling hay bailer, and heavy work. The tires have never touched anything
