will not idle
d.naylor
08-08-2003 19:51:44
farmall A will not idle down after going to half or full throttle. you can just touch the linkage from the carb to the gov and it will idle down. checked all linkage, seem fine. can the gov be adjusted or a spring be replaced, etc to solve this problem.
thanks
Tim Kincaid
08-09-2003 08:17:22
 Re: will not idle in reply to d.naylor, 08-08-2003 19:51:44
Take the linkage loose from the the carb and see if the throttle shaft has free movement all the way thru its range. It could probably use some lubrication if it hasn't been off for awhile or the little seal has become damaged somehow. Good Luck Tim K.
ps. Butterfly could be hanging up also.
