Engine Bore of M and SM
terryjd98
08-08-2003 21:35:30
I was wondering if anybody knew if the Engine of the M and Super M were bored the same size just with different sized sleeves in them or if the Super M was a bigger bore engine.
Thanks
Terry
Doug in OR
08-10-2003 09:08:43
 Re: Engine Bore of M and SM in reply to terryjd98, 08-08-2003 21:35:30
The Super M was bored larger. You can take an M and use 4 inch pistons by using an overbore kit. They used thinner sleeves for this. You can take a Super M engine and go from a 4 inch bore to a 4.125 bore simply by using an overbore kit. These kits consisted of the larger pistons and a thinner sleeve.
You cannot take an M engine and put a 4.125 kit in it, unless you bore the engine or run it without sleeves.
randy hall
08-09-2003 07:08:35
a super m block has 1/8" larger cylinders. the sleevess are the same thickness.
Farmall Don
08-09-2003 06:40:23
I believe the M had a 3-7/8 bore and 5-1/4 stroke and the super M had a 4 inch bore and a 5-1/4 stroke. Giving a 247.7 vs 263.9 displacements in cubic inches.
