Help needed with D166 bearing replacement
Farmer Bob
08-09-2003 17:42:46
Attempting an in-frame rod and main bearing replacement on my newly acquired 340D rowcrop. Old #1 rod bearing left minor scratches on crank journal and was trying to dress it up when I turned the crank to get the other side of the journal, the rod dropped to the side of the crank and I turned the crank too far to get the end of the rod back onto the journal to bring it around another 1/2 turn.
I can not turn this engine backward! Is there something that I'm not seeing or what can I do to turn the engine backward about 15 degrees to get that rod back into the journal? Short of removing the head and pull the piston up that is!
This is my first experience with a deisel so bear with me please. Tractor is out of gear brakes off, pan off high & dry. TIA.
the tractor vet
08-10-2003 14:46:49
 Re: Help needed with D166 bearing replacement in reply to Farmer Bob, 08-09-2003 17:42:46
Either pull the T/A lever back into low or have someone hold the clutch down.
w gatewood
08-09-2003 20:42:46
where are you located? i myself have a farmall 340 diesel row crop. would love to know what your serial # is also thanks wilson gatewood
Farmer Bob
08-09-2003 20:48:47
 Re: Re: Help needed with D166 bearing replacement in reply to w gatewood, 08-09-2003 20:42:46
Wilson, I'm in Washington State on the Olympic Peninsula, My 340D is Serial # 6704SY and is a '61. I need one 340D side emblem, the oval one. Any idea where to find one in decent shape?? and where are you at?//FB
w gatewood
08-09-2003 21:08:01
 Re: Re: Re: Help needed with D166 bearing replacem in reply to Farmer Bob, 08-09-2003 20:48:47
fb i am in indiana neer indianapolis. and yes i have a 340- d side emblem. call me at 317-748-1468 or e-mail me at ihman1468@aol.com thanks wilson
Farmer Bob
08-09-2003 20:01:50
Duh! Answered my own question. The TA lever has to be in rear position to turn the engine backwards!!! Learn something everyday!//FB
