rubber or steel??
Rob
08-09-2003 18:10:22
I am wondering if the F-12 widefront came with rubber tires or steel wheels or both? I have a widefront but it has the original wheels cut off, there are 4 flat spokes welded to a car rim. I would also like to know how much a belt pulley would be worth? (ballpark!)
Fred
08-10-2003 06:46:42
 Re: rubber or steel?? in reply to Rob, 08-09-2003 18:10:22
The F-12 came with rubber or steel wheels. It was common to cut the steel off and weld rims on the flat spokes so they could put rubber tires on them. It was a lot smoother ride with rubber. They are called cut-offs and sounds like that is what you have. Most people put tractor rims on.
Guy Fay
08-09-2003 20:24:58
Both.
