H Head Bolt Length
WIRED
08-09-2003 21:12:36
All,
Just got the block back today from the shop (so purdy...) and they plucked all the head bolts off (even managed to break one, drill and tap it out). I now have a mix of long ones and short ones. Can someone point out where the long ones go? I think there are 5 of them.
Restoration of the '41 H is nearing the 1/2 way point. There is nothing left on the chassis but the rear axles, and they are coming off tomorrow so I can put new gaskets on. This was my first full bolt-off restoration. I have about 4.2 million parts in zip lock bags in the shop right now, cleaned, and ready to begin the great reconstruction project.
Thanks.
randy hall
08-10-2003 18:37:03
 Re: H Head Bolt Length in reply to WIRED, 08-09-2003 21:12:36
the long ones go where the throttle pivot mounts and where the head has the steel tubes cast in.
Dave_Id
08-10-2003 08:48:20
Just lay the head on the bench and stick the bolts in the holes, place them so that about 3/4 to 1 inch sticks out of the block underneath.. after changing a few around, you should be able to get the right lengths in the right holes.
howster mighty fine
08-10-2003 05:12:34
I've got an H block out in the shed. I can go look later if someone else don't reply.
