Order Farmall Cub Parts Online
Cub charging woes
Kirk
08-10-2003 08:28:59
O.K. Here's the situation. I recently installed a new clutch in my 53 cub - once it was back together the charging system that worked now does not. I have replaced all the wiring, the belts, voltage regulator and generator tested - replaced the amp gauge. When I turn on the lights it shows a discharge - why is it not charging? Is there anything that I can test? I have a voltmeter ... where do I go from here? PLEASE HELP!!
Bob M
08-10-2003 09:35:33
 Re: Cub charging woes in reply to Kirk, 08-10-2003 08:28:59
Kirk - Punch below. The info there may be of help...
