weak loader
Mike (IL)
08-10-2003 17:36:24
I have a M with a loader the seems a weak. It has a m&w pump on the engine. I think the pressure valve maybe bad. it work good until i have weight in the bucket then i has trouble lifting. I am thinking about replacing the valve and see what that does. my question is... what size valve should i get? what should the pressure be for a loader? It is possible that it is not even the correct one on there.
thank you Mike
Nebraska Cowman
08-10-2003 17:44:57
 Re: weak loader in reply to Mike (IL), 08-10-2003 17:36:24
I'm thinking that the original belly pump put out aroung 950 lbs new. The M&W likely the same. Not much to raise a loader unless the cylinders are quite large. Even then it would be slow. Most loaders around here run external PTO pumps.
