behlen power steering on 400 farmall
armstrong
08-11-2003 15:49:25
power steering won't work,
mbnok
08-12-2003 18:34:51
 Re: behlen power steering on 400 farmall in reply to armstrong, 08-11-2003 15:49:25
Do you have power steering.
I bought a 400 once to replace one I had, drove it home and looked, it didn't have it (power steering). Does your lift work? Check reservoir for oil? Pull hose off inlet to unit to see if oil will come out with tractor running. Its nice to have a guage to stick in there. Get the answer to these and someone will have better sugestions.
armstrong
08-13-2003 18:41:30
 Re: Re: behlen power steering on 400 farmall in reply to mbnok, 08-12-2003 18:34:51
i have changed oil and cleaned filter and bled the system, none of these helped
mbnok
08-16-2003 19:19:44
 Re: Re: Re: behlen power steering on 400 farmall in reply to armstrong, 08-13-2003 18:41:30
Are you getting flow and pressure to the steering unit.
Put a cylinder in the remote, does it move steadily? When the cylinder reaches the end of its travel does it kick the lever to the center. If you don't have a cylinder do you notice a load on the system when you lighly pull on any lever and it should immediately kick it back to center unless you are holding it. If it doesn't do any of these things you probably have pump problems.
