carb dripping on fresh rekit on 560 help please
big red 1
08-11-2003 18:18:47
Ive got a drip its comung out the very bottom of the carb where yiu replace the felt and the retainer which I did,any ideas on stuff I could try to fix this drip,other than that carb seems to function fine
thanks in advance
Nebraska Cowman
08-12-2003 04:46:41
 Re: carb dripping on fresh rekit on 560 help pleas in reply to big red 1, 08-11-2003 18:18:47
If it is just a slight drip it might be the valve is not seating and may fix itself. just keep the fuel turned off. Could be float setting too. Doubt it the float is bad. when they sink you know it.
CNKS
08-11-2003 18:41:25
Your float is sticking, and not completely stopping fuel flow, replacing the felt and retainer had nothing to do with it -- hard to fix sometimes, I just shut off the fuel.
Chuck
08-11-2003 21:28:14
 Re: Re: carb dripping on fresh rekit on 560 help p in reply to CNKS, 08-11-2003 18:41:25
This can be frustrating. A couple of ideas-Recheck float height to make sure it's not letting the bowl run over.Double check the float to see it is not leaking. A tiny amount of gas in the float will make it too heavy to seat the needle tightly. Make sure the gasket is good between the seat and the carb body. Good luck...
