Order Farmall Cub Parts Online
Cub Governor
tiny
08-12-2003 22:07:16
I just traded for a Farmall Cub, and the governor has slack in it. The engine will idle up slightly, and there is about 3/4 inch slack with engine off in the cross rod from the left side to the governor. I figure it is just worn. Is there any site where I can view a diagram of the cub governor and how it works PRIOR to my attempting to repair it? Thanks,
Phlogiston
08-13-2003 05:21:09
 Re: Cub Governor in reply to tiny, 08-12-2003 22:07:16
There is a key on te end of that shaft. Pull the rod out, clean it and put a little bit of Loc-tite on there. Let it set up over night. You do not want any slop in the rod at all.
Phlogiston
Tiny
08-13-2003 08:44:39
 Re: Re: Cub Governor in reply to Phlogiston, 08-13-2003 05:21:09
Okay, I didn't want to do like I did on an "A" John Deere one time. I took the 5 bolt end plate off the left side of the engine, and the govenor balls went everywhere. Thanks for the help.
