Farmall A build year/serial number
Jim Isler
08-13-2003 07:55:05
My A has a replacement block and the seat bracket is gone, so no serial number. I have the following info off the machine:
Oil Filter number is IH 376375 R91 (168)
Zenith Carburator
Casting Codes:
Right side drop gear 6828-D
Transmission top 6832-D
Torque Tube/Bell Housing 8638 DE
Governor Front 6340-D
Front Frame 6530-DD
Other clues: starter and regulator installed. There is a dipstick in addition to the "check plugs".
Where can I go for help in determinging year? Fay/Kraushaar book doesn't help.
Brad Sanders
08-15-2003 19:50:58
 Re: Farmall A build year/serial number in reply to Jim Isler, 08-13-2003 07:55:05
The casting date for each of the major parts should be visible. The last character will be a letter that will tell you the year if you check the Farmall Letter Series book by Guy Fay. My 1946 A has a date on the block (P for 1946), and a date on the torque tube and transmission case. The first casting was in February 1946 and the last was in May of that year.
Reddog
08-13-2003 20:20:51
Jim, You don't live in GR Michigan by chance? I used to know a Jim Isler who lived in the Grand Rapids area.
Jimisler
08-14-2003 10:33:24
 Re: Re: Farmall A build year/serial number in reply to Reddog, 08-13-2003 20:20:51
No, I live in Colorado. I did correspond with that Jim Isler several years ago on a geneological matter. Don't think he's into tractors.
Glenn-WV
08-13-2003 09:54:22
The numbers you listed are part numbers, not casting dates(other than the oil filter). Look for something like this:
12*18*E
where the star(*) I types represents what looks like the head of a bolt. It reads like this:
month*day*year
and years are represented by letters. Post your findings and we'll help figure it out. :-)
Glenn-WV
08-13-2003 09:59:38
 Re: Re: Farmall A build year/serial number in reply to Glenn-WV, 08-13-2003 09:54:22
My mistake - the oil filter number is also a part number. The fingers type faster than the brain thinks, sometimes. Sorry about that.
