Starter Switch on H
marvin
08-13-2003 15:43:38
I have replaced the starter switch on the H and it worked fine for a short while. I then pulled the switch apart , cleaned and put back together and it worked a while longer. It is now not working again. I am assuming that it is not working since I measure an open across the switch contacts. So there must be oxidation or carbon on the contacts. How do I fix this problem without buying a new switch?
Jailkeeper
08-13-2003 16:35:07
 Re: Starter Switch on H in reply to marvin, 08-13-2003 15:43:38
I would suggest you just bite the bullet and replace the switch. It would be a lot easier than fooling around with your old one every time you want to start your tractor.
