504 wide front
Kevin
08-13-2003 18:34:28
I have Farmall 504 Diesel NF and would like to put a wide front end under it. I've seen one with a Norden front ( I think )that I liked really well. The question I have is I've seen a Norden under a 460 and was wondering if that one will work or is there another I should use? Thanks for your help.
ChrisNCharge
08-18-2003 18:05:07
 Re: 504 wide front in reply to Kevin, 08-13-2003 18:34:28
I have a Norden wide front off a 460D for sale. Email me and I will send pics, the bolt pattern under the tractor is 5 1/2" wide +- by 11"front to back +- You can call me @ 254-913-2081
Todd Frampton
08-13-2003 19:13:46
Kevin,
I have a 1962 504D that was originally NF. Purchased with an Oliver wide front in 1998. I did some work to it by spinning the front 180 degrees (so the front axle was more forward) and made custom steering linkage with hiem rod ends (one long rod from steering knuckle to knuckle like 1975 Ford 4x4 trucks) and one tie rod from center pivot to pass side knuckle. Works good. Just have to make center bracket so last tie rod is at sufficient angle for proper turning radius side to side.
Todd
