Touch Control Pump Question
scotty
08-14-2003 05:17:53
If the touch control pump is leaking hyd fluid back into the motor what is the most likely culprit? After taking the pump apart, it seems as the o-ring in the bore that drives off the govenor gear might be allowing fluid past that point. Any ideas.
Thanks
scotty
EZ
08-14-2003 05:32:28
 Re: Touch Control Pump Question in reply to scotty, 08-14-2003 05:17:53
scotty,
I've seen many posts on this subject on the Cub board. The culprit always seems to be the O ring(s) at the pump end. Easy fix once you have the parts.
scitty
08-14-2003 06:31:20
 Re: Re: Touch Control Pump Question in reply to EZ, 08-14-2003 05:32:28
Ez, Thats what I kind of thought, I will probablly just order the whole rebuild kit but I know some of these guys on here have done a bunch of rebuilds on these units. The wx has been scorching down here lately, kind of looking for some cooler wx. Were goin up to the Vt house tonight, looks like it might be a little cooler up there. Talk to you later.
scotty
