PTO RPM?
tj
08-14-2003 06:10:04
Just got my "new" M. There is no tachometer on it. Was there one originally? If not how do I know my PTO speed?
Thanks for any help
tj
Tom W.
08-14-2003 06:33:20
 Re: PTO RPM? in reply to tj, 08-14-2003 06:10:04
no tach on an M. The PTO speed is 540 RPM at full speed.
Hugh MacKay
08-15-2003 01:33:14
 Re: Re: PTO RPM? in reply to Tom W., 08-14-2003 06:33:20
Tom: Most of the old gas Farmall I had before the days of tachometers tended to be on the slow side of 540 as they were set from factory. The best inexpensive check was the plunger strokes on a baler.
Dr.EVIL
08-14-2003 11:48:49
Wayne's right, Yur M is supposed to have a full load engine RPM of 1450 RPM, and a PTO speed of 537 or 539 PTO RPM at full load. But at no load, the engine MAY run as fast as 1595 RPM with a PTO RPM of 595 rpm. But I think You'd need a really steep hill with a big load pushing You to get the engine running that fast.
Wayne Swenson
08-14-2003 10:38:51
All tractors will run somewhat faster than their rated PTO speed (Rated 540 for example may run @ 570-580) until a load is applied.
The manufacturer's rated PTO is set under load conditions.
tj
08-14-2003 07:57:32
OK so open throtle will give a PTO of 540.
thanks Tom W
tj
Andy Martin
08-14-2003 13:58:21
 Re: Re: Re: PTO RPM? in reply to tj, 08-14-2003 07:57:32
Yes, assuming your tractor is not overspeeding.
I run a JD 348 baler on an M, the baler book calls for 80 strokes per minute, and at full throttle, under load, I get close to 100 strokes per minute.
I run the tractor at part throttle and get better results with the baler.
I have never measured the tractor RPM, or the PTO, but if mine can run fast so can yours. Run the tractor at the speed that works the implement well.
