RPM's on an M
Big Red
08-14-2003 15:15:08
Hey guys I just pressure washed the M today and when I took it back to the barn to put it in the shed I noticed that when I pull the throttle back around 25% it has a surge I guess you would say in the idle. It's like it won't stay at the adjusted RPM change when you pull the throttle back. It idles fine but the rpms jump up and down when you pull the throttle back. What's wrong guys? Thanks for the help..
49 Cubber!
08-14-2003 17:42:13
 Re: RPM's on an M in reply to Big Red, 08-14-2003 15:15:08
Spring inside the governor.
