Farmall 340 problems
Joe
08-14-2003 19:19:19
my farmall(not utility) 340 hydrolic lift cylinder on my fast hitch is not working right. when i move the lever a little bit it should raise the inplement just a little but in stead it raises it a foot or more and i lost my fast hitch manual. also my tranny make a grinding type noise when shifting gears and i haft to pull back the torque amplifier and it dosent do it.
K.B.
08-14-2003 19:43:10
 Re: Farmall 340 problems in reply to Joe, 08-14-2003 19:19:19
The shifting problem is an easy one to fix. You need to ajust the TA and clutch linkages. You'll need a service manual to do this, the ajustment needs to be exact, and it is too hard to explain, you just got to have the diagram to look at. Get yourself an I&T Manual, they're cheap and it has a good diagram of the linkage.
