Farmall H oil pump
SCOTT IN MO
08-14-2003 20:15:26
I was getting ready to overhaul may H . Was wondering is there any place to buy a oil pump re build kit I was told it's a good idea to have this done. Maybe a price if anyone ever rebuilt one before . thanks
Theman
08-15-2003 12:29:25
 Re: Farmall H oil pump in reply to SCOTT IN MO, 08-14-2003 20:15:26
The H oil pump wasn't really designed for rebuild. I have taken two so-so pumps and made one from the best parts. It works great and produces a lot of pressure, but I do NOT recommend this. It was a lot more trouble than just getting a good pump somewhere else.
The gasket set for your rebuild will include a couple of shims for the bottom plate. They won't be necessary if you get a good pump. Put them in a safe place in case you need them later.
another doug
08-15-2003 04:51:03
Scott, how does this pump come out? two cap screws underneath, then does it just slide out , maybe with a little prying?
JPY
08-15-2003 12:50:32
 Re: Re: Farmall H oil pump in reply to another doug, 08-15-2003 04:51:03
Take the screws loose and twist it a little and it comes right out.
justin
08-14-2003 20:56:35
I have a NOS one available
