1964 farmall model 1066 question
rick
08-16-2003 19:24:57
i have a 1965 farmall model 1066.my question is how do you get this model to not roll while in neutral? i can put it in neutral engage park but it will still roll.it looks to me like park is just a neutral lock.appriciate any info.
RPM
08-19-2003 07:26:44
 Re: 1964 farmall model 1066 question in reply to rick, 08-16-2003 19:24:57
Reading your posts and the answers, your model or year of tractor is not correct, look at left side of this forum about half way down it will have serial numbers for your tractor, the actual serial begins after the U (for US built), the park is prone to fail, and always need adjustment, sounds like you have a IH replacement non adjustable style, I would get a spring-loaded type from AG-Parts 800-445-6698, their part # 830244, should be about $30, I dont know if they will sell retail to anybody.
rick
08-21-2003 19:39:45
 Re: Re: 1964 farmall model 1066 question in reply to RPM, 08-19-2003 07:26:44
o.k. thank you all for taking the time and effort from your knowledge to answer my question.again thanks to all..
Bermuda Ken
08-16-2003 19:55:24
If the tractor does not have a gear click or skip when driven in reverse, you MAY be lucky enough that the park lock needs either adjusting or the park lock pawl is broke.
Adjusting is easy, replacing the pawl takes a lil time.
Are you sure its a 1964 year model 1066??? I have never heard of one of those..... ...
rick
08-18-2003 14:26:25
 Re: Re: 1964 farmall model 1066 question in reply to Bermuda Ken, 08-16-2003 19:55:24
i can see no way to adjust the park lock.it only moves up to allow you to put it in gear,or down to lock it in neutral.and where is the pawl?
boog
08-17-2003 19:44:30
The 66 series tractors didn't come out until the early '70s. Sure it isn't a '74 1066?
rick
08-18-2003 14:29:42
 Re: Re: Re: 1964 farmall model 1066 question in reply to boog, 08-17-2003 19:44:30
the fellow told me it was a 1964.how do you tell what year it is?
the tractor vet
08-17-2003 14:38:40
Neither have i but anyhow it would be in your best intrest to install a spring loaded park lock package as they are not hard to install and it could save your life our someone else.
rick
08-18-2003 14:38:52
 Re: Re: Re: 1964 farmall model 1066 question in reply to the tractor vet, 08-17-2003 14:38:40
where could i get a spring loaded park lock package?and what do they cost?thanks
scotc
08-18-2003 18:10:36
 Re: Re: Re: Re: 1964 farmall model 1066 question in reply to rick, 08-18-2003 14:38:52
go to your nearest case ih dealer, its an update kit for IH park locks, they can order one if they dont have one, you will have to pull up the deck and open the range transmition but rather simple really. Also dont trust parking it in gear to hold the tractor if its got a t/a
rick
08-18-2003 20:13:21
 Re: Re: Re: Re: Re: 1964 farmall model 1066 quest in reply to scotc , 08-18-2003 18:10:36
scott thanks for the info. maybe won't be long till i get it to sit still in neutral.thanks again.
rick
08-18-2003 14:32:59
where could i get aspring loaded park lock package and what it cost?thanks
JW
08-16-2003 19:49:19
Your park lever should be a park lock. Sounds like you may have something broke, in a Case its usually the park pawl from someone trying to put it in park while its still moving.
rick
08-18-2003 14:47:10
 Re: Re: 1964 farmall model 1066 question in reply to JW, 08-16-2003 19:49:19
i can't see anything broke where you can see it.it's been like this since i've had it.but i hate to cut the motor off in the winter to open a gate,then cut it off to close the gate.where is the pawl located?all the park lever does when you move it down is slide up to lock it in neutral.nothing else moves.thanks
