706D Wont start off button
craig
08-17-2003 16:19:48
My 706d is had to get to start from the push button. When I jump across the solienoid with a screwdriver it will start right away with no hesitation. I bought a new solienoid last year, and this hasn't sloved the problem. Any suggestions?
BIG JOHN
08-17-2003 19:12:35
 Re: 706D Wont start off button in reply to craig, 08-17-2003 16:19:48
More than likely you will find that it is the Clutch Safty Switch. It gets used every time that you clutch the tractor so they wear out much faster that the starter button. I have replaced mine three times. Each time the tractor starts just as you described. It easy to check this switch, just connect the two wires together and try the starter button.
GOOD LUCK
K.B.
08-17-2003 18:21:13
Several possibilities. 1- bad connection on the wire from the key switch to the push button, bad connecton on the wire from the push button to the clutch saftey switch, bad connection on the wire from the clutch saftey switch to the soleniod. 2- bad push button or clutch saftey switch. 3- clutch saftey switch needs ajustment. Whatever the problem, get it taken care of right away, you're bound to run yourself over jumping the soleniod.
Red Man
08-17-2003 16:42:22
Replace the starter button switch, had to do that on my 350 2 years ago.
REDMAN
08-18-2003 13:06:30
 Re: Re: 706D Wont start off button in reply to Red Man, 08-17-2003 16:42:22
can't think of your own name or what?get a clue
Red Man
08-18-2003 16:26:48
 Re: Re: Re: 706D Wont start off button in reply to REDMAN, 08-18-2003 13:06:30
I've been Red Man ever since I've been on YT and Red Power forums, I lurk here a whole lot, post occasionally, so maybe YOU need to get a grip.
