400 / 450 heads and blocks
Bill Evans
08-17-2003 17:13:45
How similar are the heads and blocks on a 400 and a 450? Could 450 sleeves / overhaul kit be installed in a 400 block?
randy hall
08-17-2003 17:45:00
 Re: 400 / 450 heads and blocks in reply to Bill Evans, 08-17-2003 17:13:45
the late 400 blocks and the 450 blocks are cast heavier in the bores.the gasoline heads are the same. yes you can use a 450 overhaul kit in a 400.
