International Super A....is there such a thing?
Rauville
08-17-2003 17:31:16
I'm looking at a "International Super A", serial 353XXX. Nice tractor that was repainted about 30 years ago, and International, Super A decals were "replaced" at that time. To me, it looks just like a Farmall Super A, only with a square front axle, and foot gas pedal. Was there ever such a thing?
another doug
08-18-2003 04:27:57
 Re: International Super A....is there such a thing in reply to Rauville, 08-17-2003 17:31:16
Yes, we have had this one for about 38 years, took off the side mounting sickle bar mower(still have it) was owned as a county hi-way mower tractor , but we found that a 42" Woods belly mower worked better for our use....has the foot throttle as well as the quadrant mounted one and the square axle...magneto ignition,thermal siphon cooling system...
Sid
08-18-2003 04:12:11
There was a mid-mounted mower produced for the International Super A called the AI-23 Highway Mower for mowing highway shoulders and banks, golf courses etc. The cutter bar would cut at any angle 90 degrees above horizontal to 45 degrees below horizontal.
BIG JOHN
08-17-2003 19:05:32
In addition to the square front axel and the foot feed there is a transmission break built into the transmission that helps when shifting on the go. The book also says that it is about 1000 lbs heaver that a Farmall A. Very few were equiped with a belt pully. I have one and with these exceptions I have found that All Farmall parts fit the International.
Dave BN
08-17-2003 17:44:19
Yes, I believe this is a legit version of the A. Some of these did not have lift-all and I beleive the front emblem should say INTERNATIONAL not FARMALL, and the square front axil is correct. Not sure about that serial number though. Dave.
CNKS
08-17-2003 18:24:23
 Re: Re: International Super A....is there such a t in reply to Dave BN, 08-17-2003 17:44:19
Description fits International Super A, first 3 digits of the serial makes it a late 1953-early 1954, it is not a Super A-1.
