H CARB PROBLEMS
FARMIN RED
08-19-2003 05:34:50
I just brought home a 1947 H and am trying to get it running. I took off the carb and took it apart and found that the float was all gummed up. so I freed it up and made sure that gas was running through it before I put it back together. when I got the carb back on the tractor I tried to start it. I pulled the choke and cranked. when I pushed in the choke and quit cranking a mass amount of gas came out of the air intake end of the carb. what happened, what did I do wrong and how can I fix it. thanks for the info in advance.
Bill Smith
08-19-2003 14:23:09
 Re: H CARB PROBLEMS in reply to FARMIN RED, 08-19-2003 05:34:50
Two possible causes. With gas turned on under the tank the carb should not leak out gas like you were saying. If it does, then you got a float and needle valve problem inside the carb. If it only does it for a little bit after choking, then you are simply overchoking it. If this tractor is in fair running condition it should only need very minimal full choking to start. If I need to choke mine, I go all the way and let all the way off right away while cranking. Very rarely do I need to parshaly choke for the tractor to run (only during cold weather untill tractor is warmed up).
Chads
08-19-2003 08:52:02
It sounds like the float is going too high. It is overflowing out the metering stem. I don't know the proper float adjustment, but I flip the carb upside down and bend the float so it sets level when closed, and drops down about 1/4 inch when the needle opens. Hope this helps. ChadS
FARMIN RED
08-19-2003 08:13:25
WHAT ARE THE PROPER ADJUSTMENTS TO THE CARB?
Theman
08-19-2003 08:10:32
What you are seeing is a common symptom of this model. The design of the H carb is such that very little choking is necessary to richen the mixture in the cylinders. 2 revolutions at full choke is about all that should be done at a time.
Rich[Wi]
08-19-2003 10:28:02
 Re: Re: H CARB PROBLEMS in reply to Theman, 08-19-2003 08:10:32
On my '47 the only way to use the choke is to pullitoutpushitin just that quick or it will flood.
rustyfarmall
08-19-2003 06:19:01
Your life will be a lot easier if you go ahead and do a total rebuild of that carb right now. Otherwise, it will never be right.
