IH Super M Generator question
Chad
08-19-2003 09:17:30
I had a quick question regarding generators that I was hoping the experts at this forum could possibly help me out with.
I have a '54 SMTA that I was given to me as a gift a couple of years ago (it was a fairly large stocking stuffer but a great gift nonetheless). It runs great except for the charging system. That has always been a source of trouble since I've had it. We had the generator pulled off and tested and NAPA said the generator was OK. So, Dad and I being the curious people that we are, we did the absolute wrong thing and got to playing around the voltage regulator with a screwdriver (FYI: That's not a smart thing to do when you don't know what you're doing). Anyway, while the tractor was running Dad connected something that made the generator howl like a banshee. Ovbiously, that didn't make the tractor charge.
Would anyone know what we caused to the system or how it could scream like that? Are there some checks that I can do to verify whether I've completely screwed the generator? When I checked the system with a multimeter, I don't get charge at all. Looking back, the system probably just wasn't polarized or properly grounded but I have a feeling that we caused some other problems. I learned the hard way that it's a smart idea to do your homework on problems before you tinker with screwdrivers.
I'm going to have to put my game face on and tackle this problem because I'd like to use the M to do some baling.
Thanks for you help,
Chad
Bob M
08-19-2003 11:14:03
 Re: IH Super M Generator question in reply to Chad, 08-19-2003 09:17:30
Chad - Punch below for a troubleshooting chart that may help diagnose the problem. Other than a loose drive belt or possibly a bad drive end bearing, I can't think of anything you could do that might cause the generator to screech.
A suggestion: If you messed with any of the adjustments inside the regulator get rid of it and install a new one (regulator settings are fussy and hard to get right even when you know what you are doing...) And if the regulator's more than a few years old it probably needs replacing anyway.
Good luck!!
Chad
08-19-2003 12:32:42
 Re: Re: IH Super M Generator question in reply to Bob M, 08-19-2003 11:14:03
Bob, Thanks for your input and the troubleshooting chart. This should get me going in the right direction.
I have to say that I've read quite a few of your posts over a wide range of topics during the past year and they have proven to be very helpful.
Thanks a bunch.
Chad
Bob M - another tip...
08-20-2003 05:58:32
 Re: Re: Re: IH Super M Generator question in reply to Chad, 08-19-2003 12:32:42
Thanks for your kind words Chad!
Forget to mention in my previous reply: If you're in a hurry to get bailing, simply slip the belt off the generator. So long as the battery is good and is fully charged when you begin, it should run the tractor ignition 8 - 10+ hours without the generator working. Then at the end of the day put it on a charger and let it recharge overnite. To get maximum run time minimize use of the starter, and DON'T use the lights!
Good luck!
dhermesc
08-19-2003 15:07:54
I agree with Bob M, go ahead and replace the voltage regulator and you might also want to have the generator checked again at N A P A to see if you "fried" anything. I have a '64 Ford PU that gave me fits (not charging, dead electrical system, all kinds of weirdness on and off) until someone suggested I might have a grounding problem. New battery cables and a nicely polished ground contact and it suddenly worked fine, that and all the new parts I had already installed.
