3 point hitch kits for M
Marv G from No
08-19-2003 11:53:40
I would like to add a 3 point hitch to my 1947 M. If you have input as to suppliers and who you think makes the best product, I would appreciate hearing from you.
smoknbs
08-20-2003 20:25:21
 Re: 3 point hitch kits for M in reply to Marv G from Northern MN, 08-19-2003 11:53:40
put one on a MD works great but as some one else pointed out it won't go low enough . found an old broken drawbar (right down the center) over laped the pieces ,welded together ,bolted it to the saginaw at the angle iron at the bottom of hitch and used the original adjustment rods to support it .now still have drawbar and full range of the 3 point.
08-20-2003 11:10:39
Thanks for the input. Looks like Saginaw may be the way to go. Love this website!
John
08-19-2003 19:15:43
Just a crazy question, what do you do for a drawbar and how does it work out? I have seen pictures of the Saginaw 3 pt and origional drawbar, how do they work together, I mean, do they take away from each other and get in each others way or do they work good together??
Jailkeeper
08-20-2003 10:06:15
 Re: Re: 3 point hitch kits for M in reply to John, 08-19-2003 19:15:43
third party image
John, I still have the original drawbar on my H, as well as the Saginaw hitch. The only problem I've had is sometimes I can't get my 3 pt. mounted blade low enough, like backing up to a ditch and trying to clean out a spot. That is the only complaint I've ever had, and that is very minor.
Irv
08-19-2003 17:19:30
I put a Saginaw hitch on my H. I think it is better than any OEM hitch I have seen. My2c
Jailkeeper
08-19-2003 13:12:33
Check out Saginaw County Tractor. They are probably the best 3 pt. builder around. I've got one on my H.
Dave_Id
08-19-2003 15:26:23
 Re: Re: 3 point hitch kits for M in reply to Jailkeeper, 08-19-2003 13:12:33
Ditto.. put one on a Farmall 300, then I got one for my Super C
two bit
08-19-2003 15:39:23
 Re: Re: Re: 3 point hitch kits for M in reply to Dave_Id, 08-19-2003 15:26:23
another vote for saginaw. I put one on my H and have two way hyd. with float.
