Order Farmall Cub Parts Online
Cub is home now.....needs a few things though
Carm
08-20-2003 04:19:29
It was a beautiful sight...Me on the cub rocketing down the road at a blistering 7mph or so! The steering is pretty loose, are the parts stilll available to fix it. It runs great..no smoke, however its not the original carb. im going to replace because choke is on wrong side. Also owner runs lead substitue and sae 30 non detergent oil. Is it necessary to do this? Thanks
Bob M
08-20-2003 10:20:50
 Re: Re: Re: Cub is home now.....needs a few things in reply to Carm, 08-20-2003 09:46:53
Carm - Take a close look at the carb shaft. Some carburetors let you put the choke shaft in from either side. Could be someone before you had the carb apart and simply assembled the choke shaft back on the wrong side. If so a couple minutes and small screwdriver can make it right again.
Carm
08-20-2003 11:22:21
 Re: Re: Re: Re: Cub is home now.....needs a few th in reply to Bob M, 08-20-2003 10:20:50
I will check that out. That would make life cheaper, then I could re direct the funds $$ elsewhere! Thanks
