new guy engine question
James Fisher
08-21-2003 07:23:18
I recently bought a Farmall M, sn FBX 286544X1. I know it is a 51' model but understood this model should have a C248 engine. The engine says C264 on it. The tractor is red(rust) the engine white(rusty). Is this the original engine or did someone put a super m engine in it? I am new to tractors but becoming addicted quickly. Any advice or help would be appreciated.
randy hall
08-21-2003 07:33:11
 Re: new guy engine question in reply to James Fisher, 08-21-2003 07:23:18
yes, your tractor has a newer block.
james fisher
08-21-2003 07:51:14
 Re: Re: new guy engine question in reply to randy hall, 08-21-2003 07:33:11
Is it from a super m? How can I tell?
CNKS
08-21-2003 18:56:47
 Re: Re: Re: new guy engine question in reply to james fisher, 08-21-2003 07:51:14
Your engine was made between 1952 and 1956. Since the SM and 400 engines did not match the chassis serial #'s of those tractors, there is no easy way to tell the year of manufacture of your engine -- unless someone else has an idea.
Stan(VA).
08-22-2003 05:00:57
 Re: Re: Re: Re: new guy engine question in reply to CNKS, 08-21-2003 18:56:47
Look for a date casting code on the engine block. Format is *4-13-X* which is read 'month-day-year'. If it's a C264 the year letter should be X/Y/Z/A or B which would correspond to '52 through '56.
Other parts of your tractor should have W codes if it is a '51.
Stan(VA).
CNKS
08-22-2003 12:24:11
 Re: Re: Re: Re: Re: new guy engine question in reply to Stan(VA)., 08-22-2003 05:00:57
Brain wasn't working when I posted (not unusual), and I forgot about casting codes. In addition to W, some 1951 parts have U. I guess IH skipped V because it looks too much like U.
Bob in SE Nebraska
08-21-2003 09:34:08
Look for a serial number stamped on the block. If it matches the s/n on the clutch housing it would be the original block. If it has a different s/n, you can tell the year it was made by looking up the s/n on this site.
Bob
Wayne Swenson
08-22-2003 06:16:21
 Re: Re: Re: Re: new guy engine question in reply to Bob in SE Nebraska, 08-21-2003 09:34:08
"M" numbers never did match from the factory.
"H" numbers did.
Van
08-21-2003 09:30:42
Yes its from a Super M or a 400
