200 distributor drive lube
donwisc
08-21-2003 20:39:35
Just took off the the dist to install new points and condenser. The gear drive and the inside of the housing look pretty cruddy either from poor lube or condensation. My question is how is the gear drive lubicated? Does it get oil from the govenor or is it packed with grease.
Appreciate any comments from anyone that has been into this area.
Hugh MacKay
08-22-2003 19:03:41
 Re: 200 distributor drive lube in reply to donwisc, 08-21-2003 20:39:35
donwisc: A number of years back I was advised by an IH technicion to use white automotive grease you buy in squeeze tubes. I don't even bother with the grease zerk. I just remove the plug and squeeze the grease in with tube. I have been using this close to 25 years now. The IH guy said this product was better than regular grease because of it's water resistance and is not as subject to change by temperature. He said it was just one of the improvments to come along since tractor was built.
randy hall
08-21-2003 20:50:38
take the 1/8" pipe plugs (the ones with a slotted head) out and put zerks in to grease it every thousand hours. then put the pipe plugs back in.
donwisc
08-22-2003 06:58:07
 Re: Re: 200 distributor drive lube in reply to randy hall, 08-21-2003 20:50:38
Thanks Randy, I looked at that plug and it didnt dawn on me on the purpose. This is probably the first time the unit is getting some grease.
