Right Rear Rim on Farmall A is Cast Iron ?? Wow!
Bob b
08-21-2003 20:55:50
Hi Guys,
I just got around to reading the replies to my post a few days ago about original Farmall A rear rims. What I found most interesting is what Ben in KY had to say. He said "Originally the right side was cast and the other side steel to help balance out the offset motor." I never heard of such a thing....that's really interesting. Did the rest of you guys know about the one cast rear wheel on Farmall A's, or is it not common knowledge? Now I've got to ask the obvious question...when I'm out looking for rear rims for my '39 A how do I tell the cast one from the steel one? Is it obvious, like the steel one is smooth and the cast one is pitted? Maybe I've seen cast ones in the past and never knew it.....so what do you look for? It's hard for me to believe a cast rim could be durable enough to withstand the beating a rear rim would see without cracking, but it sure does sound interesting. Now I'm guessing if the A used a single cast iron rim it would be only used on the A, as the B was a tricycle and not offset and the C used a bigger rim, no? So are these cast iron rims rather rare? If anyone has a pic of an original cast iron A rim I'd sure love to see it.
I also have to say that I've only been on this board a few weeks but you guys are great. You're full of knowledge about these tractors and willing to share it. That's very cool. Thanks for all the info you've provided and all that you (hopefully) will provide in the future.
regards,
bob
Dave
08-22-2003 18:22:21
 Re: Right Rear Rim on Farmall A is Cast Iron ?? W in reply to Bob b, 08-21-2003 20:55:50
If you come across an old wheel and can't tell it it is steel or cast iron, just try to lift it! : ) The steel wheels were stamped out of maybe 3/8 thick steel. Good luck. glad you like the board. Dave
Bob B
08-22-2003 10:36:30
Hi Guys,
Yes, I miss-understood. I was confusing "rim" with "wheel". Makes perfect sense now. Thanks for straightening me out.
regards,
bob
Dave_Id
08-22-2003 08:31:26
Yes, everyone else knows about the one cast wheel
Dave BN
08-22-2003 03:44:11
Yes, it the wheel's that are steel on the left and cast iron on the right. It is very easy to tell them apart. The cast ones are a lot thicker and heavier. B's and BN's came from the factory with steel wheels, though cast may have been an option. I have seen B's and BN's with both sides having cast wheels to add weight. Theese cast wheels are quite common. You shouldn't have any problem finding one at a bone yard. Dave.
Vern
08-21-2003 21:27:17
The "rims" are both steel. The "wheels" are different, the left one is steel & the right one is cast iron to off-set the engine weight.
All "A"s are like that as well as others with off-set engines.
