M front axle part numbers??? Help
larry
08-22-2003 12:19:09
Any one know the part number for the steering/tie rod casting that sits the tie rods in the back instead of out front for a IH wide front. Am converting a M to wide front and have the axles with the tie rods out back but do not have the part that makes the tie rods move and bolts to where the pedestal use to be. Thanks Larry
ChrisNCharge
08-22-2003 17:51:02
 Re: M front axle part numbers??? Help in reply to larry, 08-22-2003 12:19:09
Larry I believe that to be part #9 497 DAXA
Description of "steering gear arm with ball" picture shows a tie rod going to the RH side and then a arm running all the way from right to left.
Chris
ChrisNCharge
08-22-2003 17:53:27
 Re: Re: M front axle part numbers??? Help in reply to ChrisNCharge, 08-22-2003 17:51:02
Larry that part# does not bolt to the four bolts where the old tricycle bolts but clamps around the steering shaft.
