Horse Power Of Farmall C
Ed
08-22-2003 14:51:02
Hay!! Can someone tell me the horse power of a Farmall "C". I want to purchase a 9 foot haybine to cut tall grass. Also, will the "C" generate enough rpms in first gear to handle the job?
gene b
08-24-2003 04:04:11
 Re: Horse Power Of Farmall C in reply to Ed, 08-22-2003 14:51:02
Just because the haybine is 9ft dont mean you have to take a full cut.
Tractor Dan
08-23-2003 05:41:55
i usually mow with my 350 diesel but i have mowed with my H from time to time and althow the H does run it i wouldnt try to cut my heavy hay with the H the nine foot haybine works the heck out of the H i wouldnt even try it with my C witch has a very strong motor...
BIG JOHN
08-22-2003 17:56:42
18.5 Horse Power on the Draw Bar and 20.5 Horse Power on the PTO.
Suggest you look for something with more HP.
An H would have 25.5 Horse Power on the Draw Bar and 27.9 Horse Power on the PTO.
To Big John
08-23-2003 09:49:29
 Re: Re: Horse Power Of Farmall C in reply to BIG JOHN, 08-22-2003 17:56:42
Thanks for the information and advice. Ed
Jimmy King
08-23-2003 22:10:37
 Re: Re: Re: Horse Power Of Farmall C in reply to To Big John, 08-23-2003 09:49:29
I cut some green graze for a guy once with a 479 NH it was very mature and some of it in a ditch bottom was as tall as the muffler on my Farmall 460D 1st gear TA back black smoke boiling. C would be under powered on it.
