F-30 gone from the yard
Nebraska Cowman
08-22-2003 18:21:26
After a year the old f-30 fialy moved. Albeit not on it's own power. I had it belted up to the Allis but when I turned on the gas nothing happened. It is the carburator. It will run fine on carb cleaner as long as I keep squirting it. So I took off the carb but couldn't see nothing wrong. Will think about it over the weekend. But at least the tractor is in the shed now.
lucky1
08-22-2003 20:17:30
 Re: F-30 gone from the yard in reply to Nebraska Cowman, 08-22-2003 18:21:26
HEY... i rebuild carburetors for a living... try taking the carb in two and putting the air hose to all ports and passages... you would be surprised what i tiny spec of crud will do. if that doesnt work, blow back up thru the fuel line. let me know if i can be of further assistance. good luck to ya
