What's the bracket on the back of my A throttle fo
Bob B
08-22-2003 19:22:37
Hi Again,
I don't remember if I asked this question before, if I did I don't remember the answer. On the back of the throttle quadrant (facing the driver) is a small right angle bracket with a hole in the top. What's it for? My '39 "A" is magneto hand start so the only controls I have are a manual mag ground cable. Although the steering column appears to have been replaced the throttle quadrant looks original. So can someone tell me what went in that bracket or if it really belongs on my '39 "A"?
Thanks,
bob
Paul in Mich
08-23-2003 06:38:04
 Re: What's the bracket on the back of my A throttl in reply to Bob B, 08-22-2003 19:22:37
Bob, if you have a small hole (1/2 in or less) than the original mechanical kill cable was attached there. If it is a 3/4 inch hole, then odds are that the throttle bracket was replaced with a later version. This version was for the electrical ground out switch used on the later models. To my knowledge, ( I'm relying on a 64 year old memory) the 39's had just a angle attached to the steering post and not the throttle quadrant. Ours didn't last long, and we used the "dismount the tractor, thumb pressure against the magnito kill switch method".
Dave BN
08-22-2003 19:41:00
Bob, sounds like the mount for the kill switch. Is it about 1/2" diameter? I think even the crank start versions had a kill switch there. Dave.
Bob B
08-22-2003 20:02:28
 Re: Re: What's the bracket on the back of my A thr in reply to Dave BN, 08-22-2003 19:41:00
Dave, I just send you a pic of the bracket to your email address. Let me know what you think.
thanks,
bob
