856 Shifting
Robhkent
08-23-2003 11:14:06
Guys I have seen several questions refering to shifting problems related to linkage, my problem is not in linkage. I have a problem shifting my 856 into reverse. I have disconnected the linkage and am still unable to shift into reverse using pliers in top of transmission. there is a plate on the side of the transmission to the front and under the shift pivot, will this give me access to the shifting forks?? PS has a Year-Around-Cab on it.
Thanks
Rob
Robhkent
08-24-2003 19:49:25
 Re: 856 Shifting in reply to Robhkent, 08-23-2003 11:14:06
Thanks for the info Aces. To update, I disconnected the linkage again and can get it in and out of reverse with a small bar, but still cannot even with pliers. Some resistance at first but then shifts in and out easily.
Robhkent
08-24-2003 19:47:50
Aces
08-23-2003 17:30:23
Rob that on the left side of the rear end housing will let you see the shift fork but you will have to take the top plate of the range transmission to chang the fork or shaft that goes through it the cam under the range trans. could be getting bad as well. Hope this some help.
