What is the recommended Compression reading??
Farmer Bob
08-23-2003 19:40:17
Have a Farmall 340D (D166 engine) and need to know what the compression readings should be for proper operation both dry and wet would help. Have searched the manuals but they don't give a clue to this value. TIA.//FB
LAW/MN
08-25-2003 07:05:30
 Re: What is the recommended Compression reading?? in reply to Farmer Bob, 08-23-2003 19:40:17
Compression ratio -19.2:1, compression pressure at 100 RPM, 250-300 psi.
Farmer Bob
08-27-2003 21:18:02
 Re: Re: What is the recommended Compression readin in reply to LAW/MN, 08-25-2003 07:05:30
Tnks Law.
carl
08-23-2003 19:59:51
Some times the manauls dont give a compression ratio. For example the old 6.9 and the 7.3 liter v8's for ford and international dont give a compression ratio cause they want you to check them all and take a average
