Resolder Starter lead.
haycreekMN
08-23-2003 21:21:30
Anybody have any success at resoldering a broken lead in a one wire starter connection? Could or should maybe have it rebuilt anyway but want to wait till late fall for down time,,,,, thanks,,B
ET
08-24-2003 18:28:21
 Re: Resolder Starter lead. in reply to haycreekMN, 08-23-2003 21:21:30
A good big old soldering copper is the way I resolder those studs. They realy consetrate the heat. I use my oxy-acetaline torch to heat it up. Make sure the wires are clean. Tining fluid is helpful.
Michael soldan
08-24-2003 15:56:04
HaycreekMN, you can do the job but you need to clean the wires of the cable by unwinding them a few inches and take a knife and scrape as much of the wire s as you can, twist them back up and dip the cable end in "cut" acid, then heat up and sop the solder to it. "Cut" acid is hydrachloric acid that has had zinc dissolved in it, an old zinc sealer lid will work, an ounce of acid and a piece of zinc, let the zinc dissolve and you will get a good solder job. "cut acid is really good for radiator work as well. Good luck from Mike in Exeter Ontario
gm
08-24-2003 14:16:04
I believe they use a much hotter solder than what you can do with a regular soldering iron. You might try one of those propane torch setups that you use for pipes. I had that problem with mine once, got the guy at the shop to tack it on. Then turned out the gear bit was screwed up as well. A new/rebuilt starter is usually ~$200, depending on the tractor. -Greg
Dan
08-24-2003 10:20:37
I assume you are talking about the one that goes to the bolt where power goes into the starter? have done it but not a pretty picture. Heed a soldering iron or something to put heat on a large area. I changed mine from the old lever push button top of the starter to a regular bolt with a solenoid and push button start. I think I may have resorted to using a oxy/acetelyne torch with small tip and heating sparingly
Nebraska Cowman
08-24-2003 04:26:50
seems I did that once but it was a long time ago. Good luck. you will need it.
